puxho30
Mar 06, 2016Aspirant
Frontview problem readynas pro 4
Hi, I install the last firmware (4.2.28) and I´m not activate the SSH. The forntview not display the information. Could you please, help me ? Best Regards
- Mar 06, 2016
The reallocated sector count of 262159 on the disk is huge. Looks like your disk is bad.
puxho30
Yes Mdgm, I use windows 10, windows 7 and Linux, all the sameresult. I install OS 4.2.27, 4.2.28 (other version I can`t connect 168.168.168 because DHCP didn´t work).
Best Regards
Leandro
mdgm-ntgr
Mar 06, 2016NETGEAR Employee Retired
How did you update the firmware and try different firmware versions?
I have sent you a PM.
- puxho30Mar 06, 2016Aspirant
Yes, I try 4.2.20, 4.2.21, 4.2.22 ( this versions, the eth0 not connect to the DHCP) I don´t know. I use this 27 and 28 becuase connect to the dhcp. I try to change the IP address and connect directly.
Best regards
