beaumonr
Feb 24, 2019Aspirant
Frontview Users and Share permissions
Hi,
I'm having a nightmare with share and file permissions and wondered if someone can help.
Its a very simple set up, home network with a 2 ReadyNas Ultra 2's, they are main and back up usin...
- Feb 26, 2019
beaumonr wrote:
But surely it's not the underlying Linux system that's the problem it's the Front view implementation of the permissions functionality.Frontview is using a freeware package called SAMBA for the network shares (as do all linux NAS).. Managing file attributes generally is a bit tricky, because Windows file permissions don't map directly to Linux file permissions.
beaumonr wrote:
but am I trapped with the legacy operating system or is there an upgrade path?It is possible to convert one or both or your Ultras to OS-6. Netgear doesn't support that setup, so you would be on your own (meaning that you wouldn't be able to use paid Netgear support after the conversion).
Many people here have done it, and generally they seem happy with the results. Personally I've left my Pro-6 running OS 4 - it's only used for back-up now. But the next time I need to expand it's storage, I'll convert to OS 6.
I'm also a home user, but since we use a single NAS user account, I wouldn't run into your problem. I've seen the ownership/permissions issue come up here from time to time with OS 6, but not nearly as often as it shows up with OS 4.
beaumonr
Feb 26, 2019Aspirant
Yeah it's crazy, like if you buy a washing machine but it doesn't like washing towels and you need to fiddle around with it if you ever want to wash one.
The drive bays do exactly what I want apart from this but am I trapped with the legacy operating system or is there an upgrade path?
Thanks
Thanks
Feb 26, 2019Guru - Experienced User
