iakustov
Mar 18, 2016Aspirant
fsck failing against /dev/c/c_YYYY_MM_DD_HH24_MI
Hello. Can anyone help me to get an idea of how to fix the following.. During each boot there is fsck scheduled and I get the following in the configured email: fsck 1.42.12 (29-Aug-2014)
- Mar 20, 2016
I didn't get all the information needed to login.
I have replied to your PM.
mdgm-ntgr
Mar 18, 2016NETGEAR Employee Retired
When the online filesystem check is run, a snapshot is created and the filesystem check is done against that.
Can you send in your logs (see the Sending Logs link in my sig)?
- iakustovMar 18, 2016Aspirant
Thanks for your reply. I have sent the logs
- mdgm-ntgrMar 18, 2016NETGEAR Employee Retired
Thanks for your logs. I have sent you a PM. It seems an old snapshot wasn't removed properly. I can remove it manually.
The online filesystem check works off a snapshot. If the snapshot space is e.g. 10GB (which it is on the Ultra) and you write more than 10GB to the NAS whilst the snapshot exists the snapshot will be invalidated. In such cases the snapshot should then be removed, but for whatever reason that didn't work properly in this case.- iakustovMar 20, 2016Aspirant
Thanks for the information. Can you please try the remote logon and remove? And also list the steps how to remove it in case it happens again.
