iakustov
Mar 18, 2016Aspirant
fsck failing against /dev/c/c_YYYY_MM_DD_HH24_MI
Hello. Can anyone help me to get an idea of how to fix the following.. During each boot there is fsck scheduled and I get the following in the configured email: fsck 1.42.12 (29-Aug-2014)
- Mar 20, 2016
I didn't get all the information needed to login.
I have replied to your PM.
iakustov
Mar 20, 2016Aspirant
Thanks for the information. Can you please try the remote logon and remove? And also list the steps how to remove it in case it happens again.
mdgm-ntgr
Mar 20, 2016NETGEAR Employee Retired
- iakustovMar 29, 2016Aspirant
Thanks for sorting this out!
It appears that
# lvremove /dev/c/c_2013_01_13_07_00
and
# /frontview/bin/snapshot delete /dev/c/c_2013_01_13_07_00
fixed it.
- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
You're welcome. Btw I think the second of those commands is all that is needed to properly remove the invalidated snapshot that hadn't been removed properly.
