getyogrooveon
Mar 12, 2014Aspirant
FTP access "ECONNREFUSED"
I have setup ftp service on my readynas 102 (latest firmware). I can log in with the created ftp user from the local network using the internal ip and is set to you port 5000 and everything is work...
Mar 13, 2014Guru - Experienced User
Chirpa is indirectly pointing out that you need to forward the passive ports used by the NAS FTP server in your router.
Most people only need 3 or 4 passive ports, so you should also narrow the range being used in the RN102.
