ReadyNDSI
Oct 29, 2011Aspirant
FTP access/configurations how-to..
How do you correctly setup a ReadyNAS Duo (RND2110) for FTP usage. I don't seem to get it to work, even tho i worked in the past with FTP on my PC, just don't seem to beable to get it to work on my NA...
Oct 29, 2011Guru - Experienced User
If you go into the C volume, you should see a home directory and then also see a folder for each username you've configured on the NAS. These shares are not public.
On the timeouts - that would be one reason for ftp resume of course. Though on your local lan you shouldn't see that. Is this over wireless?
