ReadyNDSI
Oct 29, 2011Aspirant
FTP access/configurations how-to..
How do you correctly setup a ReadyNAS Duo (RND2110) for FTP usage. I don't seem to get it to work, even tho i worked in the past with FTP on my PC, just don't seem to beable to get it to work on my NA...
Nov 01, 2011Guru - Experienced User
Not with FileZilla, it works fine if you set the masquerade address to the readynas host name. (It detects the "misconfiguration" and substitutes the router's IP address).
ewok wrote: For remote FTP, the masquerade address needs to be your dyndns domain name...
Quite a convenient feature actually, since it allows you to use FTP both locally and remotely.
