Wizball
Jan 01, 2015Aspirant
FTP cannot connect due to unknown reason
Back up has been working fine then I started to get this error FTP cannot connect due to unknown reason I can connect using FTP no problem. Running on a sparc with 4.1.14 firmware installed ...
Jan 01, 2015Guru - Experienced User
We need more information.
-Is the NAS running this backup (e.g. frontview), or is it running on another machine?
-what are the source and destinations settings? Is the remote machine on your local LAN, if not where it is?
-Did it fail as soon as you upgraded to 4.1.14, or is it not related to the upgrade?
-Has any equipment changed on the network path between the local and remote machines?
