Wizball
Jan 01, 2015Aspirant
FTP cannot connect due to unknown reason
Back up has been working fine then I started to get this error FTP cannot connect due to unknown reason I can connect using FTP no problem. Running on a sparc with 4.1.14 firmware installed ...
Jan 02, 2015Guru - Experienced User
RAIDar uses broadcast packets for discovery. Some wifi setups won't forward them, so if you are using wifi on the PC perhaps see if that helps.
If the NAS is working on the LAN but isn't reaching the internet, the most common reason is an incorrect subnet mask or gateway address.
