clamatac
Jul 23, 2015Aspirant
FTP Server - No more than 11MB/s if FTPS is activated, without FTPS I get 80-90 MB/s
Hi, first of all sorry for my english. I have just bought a ReadyNas104, by now I have configured the FTP SERVER, it is easy, it works ok but one thing fails. I have tested it in my gigabyte ...
JohnRo
Jul 23, 2015NETGEAR Employee Retired
Hello clamatac,
First off, your english is amazing so don't be sorry about it. :)
I agree that the speed drop is a bit drastic, I would like to know more information for us to help you with the issue you are having. I have listed down some of them below:
-Firmware version
-I would also like to know if you have jumbo frames enabled or disabled?
I'll be waiting for your response.
Thanks,
clamatac
Hi,
thanks for your quick answer
I have ReadyNas 104 with firmware 6.2.4
Sorry, I do not know what jumbo frames are, where can i look at it?
Greetings
- JohnRoJul 23, 2015NETGEAR Employee Retired
Hello again clamatac,
It does not really say jumbo frames though, please check your MTU. Go to Network, click the gear icon and then "Settings" and see what the value of your MTU is.
Thanks,
- clamatacJul 23, 2015Aspirant
ok
1500 is the value, I have not changed it in any momment.
I have detected another problem, today the NAS 104 has crashed twice, ping did not respond, so I have to restart it manually taking out the power cable. Both times have ocurred while a couple of friends were taking files from my ftp.
I thing both things have someting in common.
Greetings
Carlos
- mdgm-ntgrJul 23, 2015NETGEAR Employee Retired
clamatac please send me your logs (see the Sending Logs link in my sig).
