MatsRahm
Jan 30, 2012Aspirant
FTP Share mounting problems
Hi. I have three ReadyNASes and one of them is currently misbehaving. Everything started early December when I upgraded Squeeze Center Server to a new version (the first version called Logitech ...
invader980
Feb 16, 2012Aspirant
Forgot to mention : Copyright © 1996-2011 NETGEAR ® | RAIDiator 4.2.19
another side note ... even when i rename the share to media 1 .... the media share stays available even after a reboot ... even thoe technically the "media" share no longer exist .... i dono how this happend but its confusing
Ok WOW im still kind of confused as to how i did this so ill try to explain (Prob solved).
1)I got the idea ... rename my share to (media1) Which makes the folders /c/media1
All worked fine share (media1) has my content in it ..... /c/media did not get deleted tho
2) Make a new share named (media) the folder i want back lol which oldy created the folder /c/Media (deleting /c/media oddly)
all went fine but media i could not access for some strange reason
3 ) deleted empty share (media) associated to folder /c/Media
all worked .. folder gone
4) Now i can rename (media1) to (media) giving me my original setup ...
Share name :Media associated with /c/Media all my content in tact
a scary toss and turn but worked fine .... for some reason the process of renaming the folder would not delete the associated path .... which is y when renamed back u get the same setup u were trying to fix .... the only thing that deleted the path was creating a share of the same name (usually not possible ) but thankfully the firmware/gui thinks it dosent exist so it lets u .
