ScuseMe1
Nov 12, 2015Aspirant
Garbled NV+ display after Nv+ turned on
Hi, i have a ReadyNAS NV+ V1 that's been disconnected from power for 2 months while we moved. When I finally got the NV+ plugged in and connected to my router, thy familiar "Booting...." Line comes ...
JennC
Nov 13, 2015NETGEAR Employee Retired
Hello ScuseMe1,
Can you still access the files? If you still can, back up the data. You may have to depend on the RAIDar now since display screen doesn't seem to work as it should.
Garbled display is a HW problem that you may need to replace the chassis already.
ScuseMe1
Nov 16, 2015Aspirant
Thanks for responding JennC.
Everything else with the NV+ seems fine. The display does show parts of what it normally shows (IP address, etc.) but there are other extraneous characters that I don't recognize. These characters change to different ones throughout the days. FrontView shows everything ok. I also ran a diagnostic of the drives and that was fine too. The display turns off in a minute or 2 after booting and since it's only 2 lines, it only shows the space remaining and the IP address.
Honestly, it only bugs me because it's there. My NV+ is 7 years old and has run well, other than the fan and power supply I had to replace. But it means something....
