pbarp
Feb 16, 2013Aspirant
General Protection fault (GPF) Ultra 2 hangs unresponsive
I am getting frequent general protection fault (GPF) errors on a readynas Ultra 2 which require having to press/hold reset button on front of unit to reboot. Several people have complained about a s...
Mar 18, 2013Guru - Experienced User
You could try an OS reinstall from the boot menu (NOT a factory reset). Do you have a backup?
The OS reinstall shouldn't wipe your data, though it will reset the admin password and the IP configuration.
Also, you should probably start up a new thread. If you have any logged information on the details of your specific GPF, you should include it.
