NAS_ARGH
Nov 10, 2013Aspirant
Generate a certificate????!!!!?!?!?
How in the world can one generate a security certificate with this Hunk of Junk! I have a Readynas NV+ 2V (ARM) and it does not have this Frontview that everyone says will generate the certificate....
NAS_ARGH
I have tried IE, Firefox, and Chrome
IE10
Firefox 25.0
Chrome Version 30.0.1599.101 m
Before the factory reset, the certs were determined to be 192.168.1.13
After the reset the certs were then insisting on being 192.168.1.16
I cannot figure out for the life of me how to change, delete, or fix them. (I know resyncing is not going to do anything to fix the certificate problem, it is an unavoidable result of the reset, that's all...I only mentioned it because it took so long!) I did the factory reset because I could not find anyway to generate the proper credentials in the certificate.. so I figured the server was stuck/choked on this and hoped I could reset the darn thing. There is NO way to generate the cert in Dashboard like apparently there is in Frontview... at least that's what most responses to this problem seem to indicate)
IE10
Firefox 25.0
