NAS_ARGH
Nov 10, 2013Aspirant
Generate a certificate????!!!!?!?!?
How in the world can one generate a security certificate with this Hunk of Junk! I have a Readynas NV+ 2V (ARM) and it does not have this Frontview that everyone says will generate the certificate....
aks
Nov 10, 2013Virtuoso
You'll probably find your router is issuing the IP address. If you want it to stay the same, the router might have that capability (mine does). Alternatively, the Dashboard, System->Overview->Network->Ethernet Settings allows you to set a static IP address.
Once you visit the Dashboard with Firefox/IE you can create an exception for the certificate error. I don't think the NV+ v2 has the ability to generate one.
Or is there some other issue you are trying to solve?
