NAS_ARGH
Nov 10, 2013Aspirant
Generate a certificate????!!!!?!?!?
How in the world can one generate a security certificate with this Hunk of Junk! I have a Readynas NV+ 2V (ARM) and it does not have this Frontview that everyone says will generate the certificate....
NAS_ARGH
Nov 16, 2013Aspirant
I am not a certificate guru but...
I did delete it/clear it... when you go to the IP address of the NAS (192.168.1.3) it will come back to you and say "The security certificate presented by this website was issued for a different website's address"
when you click on the "Continue to this website (not recommended). " option... it will then load the Readynas dashboard. In the address bar, it will be all red. When you click on the certificate error, it will give you the option to "view the certificate"
When you view the certificate, it will say it is issued to 192.168.1.16 and issued by 192.168.1.16 and give me the option then to install the certificate.
I would like to install a certificate however I would like to be able to install the certificate based on 192.168.1.3
