wayneamartin
Dec 20, 2014Aspirant
gpt vs mbr for external storage
I wanted to mount a 3 GB WD red in an Orico 3519 enclosure on one of the esata ports of my 516 readynas. The 516 is running the latest firmware 6.2.1. When the drive was formatted using windows 7 disk...
wayneamartin
Dec 21, 2014Aspirant
Thanks for the help, there is some progress. The enclosure works fine on a PC, I do not have another enclosure to try. If someone has a known working enclosure for gpt and > 2 gig I will order one. When I connect the external drive to any port usb or esata I get the file system unrecognized, but then the drive and files are visible under the shares. Backup jobs only complete when I connect to the front usb. I guess I could live with that, but the unrecognized filesystem error and that only the front usb works for backup jobs puzzles me.
