mneimeyer
Apr 04, 2013Aspirant
Hamachi 2 + lsb_core problems
I'm trying to install the logmein-hamachi-2.1.0.86-1_i386.deb file that I got from Hamachi directly.
When I try, it says it depends on lsb-core. If I do "apt-get install lsb-core" I get the error below (after I fixed all the other dependencies)
Anyone have any advice?
Matt
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
lprng
Suggested packages:
lprng-doc
The following NEW packages will be installed:
lprng lsb-core
0 upgraded, 2 newly installed, 0 to remove and 27 not upgraded.
Need to get 0B/1847kB of archives.
After this operation, 4043kB of additional disk space will be used.
Do you want to continue [Y/n]? y
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 21363 files and directories currently installed.)
Unpacking lprng (from .../lprng_3.8.28dfsg.1-1.1_i386.deb) ...
preinst called with unknown argument `'
dpkg: error processing /var/cache/apt/archives/lprng_3.8.28dfsg.1-1.1_i386.deb (--unpack):
trying to overwrite `/usr/bin/lpq', which is also in package cupsys
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Selecting previously deselected package lsb-core.
Unpacking lsb-core (from .../lsb-core_3.1-23.2etch1_i386.deb) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Matt
lprng
Suggested packages:
lprng-doc
lprng lsb-core
- senelAspirant
mneimeyer wrote: I'm trying to install the logmein-hamachi-2.1.0.86-1_i386.deb file that I got from Hamachi directly.
Matt
lprng
Suggested packages:
lprng-doc
lprng lsb-core
I tried it install too and I managed to install LSB core successfully but it caused that frontview stopped working... Also I had problems with tun/tap module (don't know why cause Openvpn works fine) so it ended with firmware reinstall...
Odesláno z mého Nexus 7 pomocí Tapatalk 2 - super_poussinVirtuosoYou want a VPN server ?
Which firmware do you have ? - mneimeyerAspirantI'm running RAIDiator 4.2.22 on my Ultra6... but I'm really interested in getting Hamachi running rather than any random VPN just because on the client side I've found it to be a lot easier to setup and because it "plays well" with other networking things (like VPNs blocking access to local network resources)
Matt
