Cutter_Buck
Dec 05, 2011Aspirant
Hard Disk Crashed on Computer Downloaded New Raidar Problems
Clean install on iMac. Down loaded newest version of Raidar which sees my NV+ fine and reports condition. Problem is when I try to connect it ask me for a username and password. I don't think I set o...
mdgm-ntgr
Dec 06, 2011NETGEAR Employee Retired
You're welcome.
I should have added that I do recommend you change the password from the default admin password. You can reset the password if you forget it.
