macosxgeek1
Mar 02, 2015Aspirant
Hard drive failure in RAID Level X-RAID2, 4 disks - RN2100
Hi, One of the hard disks in my ReadyNas 2100 is failed. I have RAID Level X-RAID2, 4 disks. My question is - do I need to power down the device itself to replace broken disk? Or is it capable kind...
mdgm-ntgr
Mar 02, 2015NETGEAR Employee Retired
Hot swap should work. Hot swap is designed for replacing dead disks or disks you no longer wish to use (e.g. to replace with higher capacity ones).
