macosxgeek1
Mar 02, 2015Aspirant
Hard drive failure in RAID Level X-RAID2, 4 disks - RN2100
Hi, One of the hard disks in my ReadyNas 2100 is failed. I have RAID Level X-RAID2, 4 disks. My question is - do I need to power down the device itself to replace broken disk? Or is it capable kind...
macosxgeek1
Mar 06, 2015Aspirant
Thank you for quick answer. I got the new disk now. And I'm planning to replace it. But I have one last question. The are no labels/descriptions on the disk bays. I mean there are lights above disk bays with bay numbers from 1 to 4. But how can I physically locate the disk? Which bay is it? What is the proper order for bays? From left to right 1,2,3,4 (facing the front panel)? Or from right to left 1,2,3 ,4 (facing the front panel as well)?
