SRMT123
Apr 05, 2016Follower
Hard drive replacement
Hello I have a ReadyNas Duo with 2 x 2tb drives installed. I use the device solely for backing up files from my Naim Audio Uniti Serve. The drives in the NAS are nearly full and so I was thinking ...
Apr 05, 2016Guru - Experienced User
If you are running 4.1.x firmware, then it is not possible - the duo v1 platform is limited to 2 TB drives.
- JennCApr 05, 2016NETGEAR Employee Retired
Hello SRMT123,
Like StephenB mentioned, Sparc based NAS which is an OS4 can only support max of 2TB size of disk. That's the first thing to check.
Also, always have full backup, esp. you are planning to replace the disks. Please also check HCL when purchasing replacement disks.
Hello SRMT123,
- JennCApr 08, 2016NETGEAR Employee Retired
Hello SRMT123,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards,
