SRMT123
Apr 05, 2016Follower
Hard drive replacement
Hello I have a ReadyNas Duo with 2 x 2tb drives installed. I use the device solely for backing up files from my Naim Audio Uniti Serve. The drives in the NAS are nearly full and so I was thinking ...
Apr 05, 2016Guru - Experienced User
If you are running 4.1.x firmware, then it is not possible - the duo v1 platform is limited to 2 TB drives.
JennC
Apr 05, 2016NETGEAR Employee Retired
Hello SRMT123,
Like StephenB mentioned, Sparc based NAS which is an OS4 can only support max of 2TB size of disk. That's the first thing to check.
Also, always have full backup, esp. you are planning to replace the disks. Please also check HCL when purchasing replacement disks.
