SRMT123
Apr 05, 2016Follower
Hard drive replacement
Hello I have a ReadyNas Duo with 2 x 2tb drives installed. I use the device solely for backing up files from my Naim Audio Uniti Serve. The drives in the NAS are nearly full and so I was thinking ...
Apr 05, 2016Guru - Experienced User
If you are running 4.1.x firmware, then it is not possible - the duo v1 platform is limited to 2 TB drives.
JennC
Apr 08, 2016NETGEAR Employee Retired
Hello SRMT123,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
