SteinyD
Apr 17, 2009Tutor
hard drive upgrade (replace existing)
I have a NV+ that has 4x750GB drives configured as XRaid and running v4.1.5. FYI, I never expanded their capability to the additional 40gb. In any case, I am about to replace the 4 drives with 4x1.5...
nvladik
Apr 17, 2009Aspirant
1. Yes, only one drive at a time.
2. I would start with the first drive, but there's should be no difference.
3. It could take up to a day per drive for re-sync, so the whole process could take 2-4 days.
4. Don't forget that you won't get the extra space right away, after you replace the first two drives, you will need to reboot a few times.
