SteinyD
Apr 17, 2009Tutor
hard drive upgrade (replace existing)
I have a NV+ that has 4x750GB drives configured as XRaid and running v4.1.5. FYI, I never expanded their capability to the additional 40gb. In any case, I am about to replace the 4 drives with 4x1.5...
SteinyD
Apr 17, 2009Tutor
Thanks ... I'm on my way. The NAS repoted 13-14 hours to initialize the drive but Frontview is telling me about 6 hours. 14% done and 5:40 to go :)
So, when it's done initializing I assume it needs to restripe the data next?
BTW, is the system unusable while this process is happening or otherwise recommended not to be used? Will I slow the process down if I'm using it (its mostly used for streaming media in my home).
Thanks again
David
Thanks again
David
bollar wrote: Do the hotswap. No reason to bring the NAS down to replace the drive. Just follow the prompts on the NAS' display carefully as you go.
