SteinyD
Apr 17, 2009Tutor
hard drive upgrade (replace existing)
I have a NV+ that has 4x750GB drives configured as XRaid and running v4.1.5. FYI, I never expanded their capability to the additional 40gb. In any case, I am about to replace the 4 drives with 4x1.5...
SteinyD
Apr 18, 2009Tutor
Thanks to you and others for your responses. The drive completed init in about 4 hours and now 23% through sync. I hope documenting this process helps some others in the future wanting to upgrade! :)
So, I'm also thinking that after I get done with this second drive I'm going to wait 48 hours before I start the 3rd and then another 48 until I start the 4th. The thought is burn in time. I would hate to see that I have a bad batch of drives especially after being stable for the last 2 years with the drives I'm pulling out.
Am I crazy and overly conservative? Should I just go for it?
nvladik wrote: You are doing fine, let it finish, it will tell you when it's ready.
1397GB is also correct.
