crnet_de
Jul 16, 2012Aspirant
Hardware Change 2100 -> Pro 4
Hi, a few month ago I took my RN 2100 from Datacenter home. Its nice, but the noise is ugly. Now I have the chance to change the case by installing the 2100 at a customers site and get a new Pro ...
crnet_de
Great!
mdgm wrote: It would work fine taking disks from 2100 (4-bay rackmount) and putting in the Pro 4.
OK - good Idea (the sparedisk)
mdgm wrote: Do ensure both units are running the same firmware version before doing the migration. You can use a spare disk (must not be from your array) to make sure the firmware is up to date on the Pro 4. If Pro 4 has old firmware relative to 2100 installed the migration may fail.
I always have. 8)
mdgm wrote: I would suggest you ensure your backup is up to date (you should do this regularly anyway)
I'll tell how it went when done.
Chris
