SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
de_niro
Feb 21, 2012Guide
WD2002FAEX HDD is compatible with NV+
your 2nd drive seems to be in bad condition,you might need to do these things:
--remove bad disk 2
--power on your device
--hot add a brand new disk once system is up and data is verified
--wait resync job until it is finished
--hot add another one new disk
By default, Xraid mode with 2 disks is actually raid 1 mode,when you hot plug one more disk then it will change to raid 5 mode automatically.
--remove bad disk 2
