SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
mdgm-ntgr
Feb 21, 2012NETGEAR Employee Retired
The NAS will format the disk. Hot-add (add while NAS is on) as suggested.
Yes X-RAID uses the capacity of the smallest disk.
For 2TB disks you should be running RAIDiator 4.1.7 or later.
Also if your 2TB disk is 4k sector you will want to do a backup followed by a factory reset. See Why you might want to factory reset a Sparc ReadyNAS
