SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 28, 2012Aspirant
mdgm wrote: Yes, you should have put the replacement disk in the slot where the failed disk was.
Okay, I have another - can I place it in there, or swap Disk 3 (the current WD 2 TB) into Slot 2?
