SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
mdgm-ntgr
Feb 28, 2012NETGEAR Employee Retired
I said to add your extra disk, I think.
Actually what I would recommend you do is ensure you have a good backup, then remove the 2TB disk from the NAS, update to the latest firmware and then do a factory default (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) with just your 2TB disks in the NAS.
