SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
Feb 28, 2012Guru - Experienced User
Not sure, but if they do you would get a refurbished replacement. If you think the drive is malfunctioning, it might be better to return it to the seller. Amazon for instance will replace with no questions asked.
SuperFlyBoy wrote: Would WD give me a new drive under their guarantee if it's running hot (but drive is accessible?)
