SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 28, 2012Aspirant
StephenB wrote: Not sure, but if they do you would get a refurbished replacement. If you think the drive is malfunctioning, it might be better to return it to the seller. Amazon for instance will replace with no questions asked.
Unfortunately, I didn't buy it in the US (as I would usually do - due to the urgent need of replacing the 750GB drive showing errors), so therefore went locally outside the US. (for even more $$!)
Will have to explore the option with the local distributor here in India...not sure anything will result from it though!
