SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 29, 2012Aspirant
mdgm wrote: Btw if you download your logs (Status > Logs > Download all logs), extract the zip contents and take a look at volume.log what is the block size?
As per the logs:
Block size: 16384
