SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 29, 2012Aspirant
Partition log:
Disk /dev/hdc doesn't contain a valid partition table
Disk /dev/hdc: 750.1 GB, 750145888256 bytes
255 heads, 63 sectors/track, 91200 cylinders, total 1465128688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Disk /dev/hde: 750.1 GB, 750145888256 bytes
Device Boot Start End Blocks Id System
/dev/hde1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hde2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hde3 4608002 1465112305 730252152 5 Extended
/dev/hde5 4608003 1465112305 730252151+ 8e Linux LVM
