SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
mdgm-ntgr
Feb 29, 2012NETGEAR Employee Retired
If you purchase disks that are 4k sector disks you will have poor write performance if you don't have 4k sector partition alignment.
