SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 29, 2012Aspirant
mdgm wrote: If you purchase disks that are 4k sector disks you will have poor write performance if you don't have 4k sector partition alignment.
Is there any benefit to using the 4k sector disks?
