SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
mdgm-ntgr
Feb 29, 2012NETGEAR Employee Retired
The NV+ (v1) can only use drives up to 2TB in capacity. With the transition to drives larger than 2TB in capacity lots of 2TB drives have been released with 4k sectors in preparation for the 3TB and 4TB drives that have since been released. Now the question you have to ask is even if your disks are not 4k sector disks and the 2TB disks you purchase aren't 4k sector disks if you need replacements in a few years time will there be non-4k sector disks available?
