SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 29, 2012Aspirant
mdgm wrote: Could still use this NAS as a backup NAS. Once you've migrated your data to a new NAS, update to 4.1.7 or later and do a factory default and then use the NV+ for a local backup of important data.
x86 ReadyNAS e.g. Ultra, Pro can be used with Crashplan though you'd need to enable SSH access to install it etc.
Right - this unit is on 4.1.8 at present.
We will see how things progress - no funds to invest in another at this time...these hard drives are pretty expensive over here.
