SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Feb 29, 2012Aspirant
StephenB wrote: BTW, with some effort it might be possible to use a PC with Crashplan to backup the NV+ (mapping the shares as a network drive). CrashPlan does not officially support this, but they do provide a guide here: http://support.crashplan.com/doku.php/r ... ped_drives. I haven't tried it myself though.
Yes, I'm doing something similar with LiveKive (AVG) for one of the directories that are most important.
Will try to look at your link when I have time - thanks for that!
