SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Mar 02, 2012Aspirant
mdgm wrote: What is the volume status? Is it redundant?
Yes, it's redundant now.
mdgm wrote: If so, have you tried a reboot?
Not after installing the third disk in the original position (Slot 1) of the 750 GB Seagate - the one that wasn't failing.
That one is now removed, in case it also starts to act up and because posts here mentioned (or as I understood) that it might limit the capacity of the other 2 TB drives...
Do slot positions even matter?
