SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All, I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors. The NV+ reports current config as under: Online, X-RAID, 2 disks, 71...
SuperFlyBoy1
Mar 02, 2012Aspirant
SuperFlyBoy wrote:
mdgm wrote: Slot positions don't matter as much as they used to, but I still personally wouldn't reorder disks. Try a reboot.
Okay, will do that first and report.
Had to reboot the unit a few times and is now showing full capacity! ^
Thanks guys for all your help!
