breweryman
Dec 02, 2014Aspirant
have i disabled raid properly
Hi, Through a stupid mistake while shelling to my Readynas Duo I accidentally mucked up all the file ownership on the drive. Now I cannot access it via frontview or ssh, however I can still see pa...
vandermerwe
Dec 02, 2014Master
No.
Could you first clarify exactly what you have done?
Were you changing things in the OS using ssh without a backup?
Did you only have one drive in the nas?
You cannot ssh in the nas at all? What happens when you try?
...and Frontview, what happens when you try to access it?
If you put the drive into the nas with the other drive you will almost certainly create a bigger problem. If hot added you will lose everything on the drive.
You may be able to read the data on the disk using linux reader with the disk connected to a PC.
http://www.diskinternals.com/linux-reader/
Alternatively you could try using a linux machine to read the drive.
Perhaps give some more detail about your access problems.
