Bogga
Mar 20, 2014Aspirant
HDD installation... am I doing it right?
So I'm very new to this NAS-thing and I honestly don't know Jack Schitt...
In my media computer I had two 3TB-drives and one 2TB-drive. I bought a NetGear ReadyNAS 104 and one more 3TB-drive...
What I've done so far is to install the new empty 3TB-drive in the NAS... moved all movies from one of the 3TB-drives in the media computer to the one in the NAS. I then moved all series I had on the other 3TB-drive in the media computer to the 2TB drive. I then removed the new 3TB-drive and installed the two "old" 3TB-drives from the media computer and made a factory reset so they go from NTFS to what they're supposed to be using in the NAS...
Now I want to move the series from the 2TB-drive to one of the newly formatted 3TB-drives and then install the 2TB-drive and format that as well... Should I remove one of the newly formatted 3TB drives so I know on which of the 3TB-drives it'll end up on? When I'm all done and have formatted the 2TB-drive so I've got one 3TB-drive with movies on, one 3TB with series on and two empty drives (3TB and 2TB), in which order/how shall I insert them? All at once or in a specific order?
Terribly sorry for all these moronic questions, but as I said I don't know anything about this and I don't want any lost data on my way to knowledge ;)
- StephenBGuru - Experienced UserDid you do a factory reset after you copied the movies to the NAS? If so, you already lost the files you copied.
With XRAID2, the disks you add need to be at least as big as the largest disk in the array. That means you can't add the 2 TB drive into your existing array (though you could use it if you do another factory reset). - BoggaAspirant
StephenB wrote: Did you do a factory reset after you copied the movies to the NAS? If so, you already lost the files you copied.
I removed the "new" 3TB where I put all movies and installed the other two 3TB before I did it... that I knew I should do ;)
Since the 2TB is still in my media computer and hence is NTFS I will have to do a factory reset to get it "NAS-ready"... or?
First of all I have to get all series on a NAS-ready HDD... as It is right now I've got the two "old" 3TB in the NAS. To be sure which of the disks the data ends up on, should I just remove one of them and then transfer all the files? Am I making any sense? - StephenBGuru - Experienced UserOk. Where you are confused is that usually you do not do a factory reset to make your drives "nas ready". A second point of confusion is on RAID. By default, you will be using XRAID. You will have a single data volume, and your files are automatically spread across all the installed disks (invisibly to you). The NAS will also protect you from a single drive failure (allowing you to replace a failed drive with a new one, with no data loss). Note that RAID does not protect against all types of failures, so it is still important to back up data that you think is critical or hard to replace.
So here's what you should do:
(a) first shut down the NAS, and remove the two "old" hard drives.
(b) then install only the "new" hard drive, and power it back up.
At this point, you will see your copied movies.
If you are not running 6.1.6 firmware, then update it now.
From here you have two basic choices - one which uses your 2 TB drive, and another which doesn't.
Option 1) - skip the 2TB drive, and get a new 3 TB drive later...
To do this, you hot-insert one of the "old" drives into the RN104. This means "put it into the NAS while the NAS is running". It should detect the insertion, and add it to the existing 3 TB array. You won't see any increase in size, the second drive is used for protection against failure.
After the NAS tells you that it has finished adding the drive, then hot-insert the second "old" drive. This one will increase your space to 6 TB (reported as 5.4 TiB on the Web UI).
Option 2) - reuse the 2 TB drive also.
To do this, first install one of the 3TB drives back in the PC, and format it for NTFS. Then copy back all the movies to the 3 TB drive.
Then power down the NAS and insert the remaining drives into the NAS ( 2TB, and 2 3 TB drives).
Do a new factory reset
When that completes, you should have about 5 TB of space (4.5 TiB reported in the web ui)
Now copy the movies back onto the NAS again.
Then remove the 3TB drive from the PC, and hot-insert it into the NAS. That should expand your volume size to 8 TB (7.3 TiB reported on the web ui).
BTW, if you do feel the need to prepare an existing drive for use in the NAS, the easiest way is simply unformat it.
There are two ways to do that. One is to use the vendor diagnostics (seatools or WDC lifeguard) to zero the drive.
The second way (in windows) is to right-click on the computer icon, and select "manage". A window will open, scroll down to the disk management section. Right click on the volume of the drive you want to unformat, and you will see an option to delete it. - BoggaAspirantThanks a lot for explaining it to me in my scenario... I've googled and checked various places on how this works, but I haven't gotten it really clear for me with how it looks for me with my scenario, but now I do! :)
Thanks a lot... I guess I'll go with option 1 for now :) - StephenBGuru - Experienced User(Note to kcallis - I forked your post to a new thread. RN104 is a very different platform from an nv+. You post is now here: viewtopic.php?f=65&t=75975)
