hexo1
Mar 18, 2012Aspirant
Help ! Folder disappeared (case #18173058)
Hi ! One of my backup folder suddently disappeared, and was no more visible under windows explorer although it was visible under the online web browser. Even worse, I renamed this folder and now th...
arjoseph1
Mar 19, 2012Tutor
I recommend that you contact support. Once you get a case #, please edit the subject of your post and add the case # at the end. Thanks.
