Bob_Nes
Dec 17, 2014Aspirant
Help A Beginner to Restrict Share Write/Delete/Rename
I'm a beginner to unix, but this all seems way more complicated than it needs to be. Someone should explain/guide newbies through the most common type of security settings. PLEASE HELP! And ...
Jan 05, 2015Guru - Experienced User
Also a duo owner... Backup and media are created by the duo initially. You don't actually need to use them, you could delete them if you want to, and not lose any services.
-When the UPS is set to "auto", the UPS itself initiates the shutdown event over the USB interface. There's a "critical power" event (don't recall the name off-hand) that is sent. If you manually set a threshold, then the NAS needs to monitor it.
-DLNA is its own service, and AFAIK the clients cannot delete media on the server. It has nothing to do with the file permissions you set on the NAS.
What version of windows are you using? What firmware is running on the Duo? What security mode is the duo set to use? (user or share)
