dkotkin
Jun 14, 2012Aspirant
HELP!! Case # 18770708
I have an ultra 4 plus. Was running 4.2.20. I installed 4.2.21 and the first time it booted was fine, but frontview said my volume didnt exist. Yet raidar showed the volume. So I did a shutdown. ...
ReadySECURE
Jun 15, 2012Apprentice
A factory reset will wipe all your data. If you have a current backup or don't mind loosing what is on there then a factory reset may help. However, the advice that was given to dkotkin is what I would suggest for you also
mdgm wrote: Please open a tech support (http://www.readynas.com/support) case. Edit the thread title (i.e. subject of first post in the thread) to include your case number. NetGear will need to remotely login to your system to investigate this issue. They will provide you instructions on how to grant them access.
