AtariPezman
Mar 31, 2020Aspirant
Help connectingt to USB drive or Network Folder via SSH
Hello. I have a Readynas 516. After a botched upgrade it will not boot to 100%. Instead I'm stuck at 99% while it loads nmb.service. I am attempting to login to the mostly functional ReadyNas ...
Mar 31, 2020Guru - Experienced User
AtariPezman wrote:
or the syntax to connect to a Network drive/folder?
Something like this should work
# rsync -a local_path username@remote_host:/remote_path
