Alberto66
Oct 09, 2012Aspirant
Help: disk replacement for RND-2150
Good morning. I'm new to the Forum, but I wasn't able to find out a similar issue: one hard-disk in my RND-2150 is going to die (some troubles during updating working documents stored inside, confirme...
mdgm-ntgr
Oct 09, 2012NETGEAR Employee Retired
Are you using X-RAID?
Regardless of the answer to the above have you considered higher capacity disks such as 1TB disks? It's highly unlikely any more 500GB disks will be qualified for this device as it's EOL.
If you use disks outside the compatibility list NetGear can and will deny support so it's even more important than normal to have an up to date backup of important data primarily stored on your ReadyNAS.
